Whitebeauty
- Oct 15, 2011
- 5,237
Well its about that time! Look what came in today! So yeah im excited been a long time waiting for some boost and for the price that i got hooked up for it was worth it!
My plans for this:
and i believe thats it. I gotta go through the kit first to see if anything is missing and then we will begin the transformation. This came off an Xr so i will be trying to use this fit kit on my 4r.
Current mods:
Fully built 1Grfe
LCE rods w/ arp2000 hardware
JE pistons
ARP headstuds
Cometic head gaskets
Ferrera Valve train
TRD S/C modded by Stiegemier: Everything except the snakebite.
Light weight rotors, Venom cooler, Ported,and direct drive coupler installed.
Throttle body bored and throttle plate shaft modded as well.
APR X1, cam gears and T-stat
Walboro 255lph with external filter.
61lb injectors- running E85
Apr fuel rails
-6 feed and return lines from fender.
APR 7th
Tomei FPR with fuel pressure gauge
APR 2.6 pulley
NST overdrive pulley kit
Volant cold air intake
NST intake manifold spacer
NST wp/alt/
Dtlt headers
Magnaflow muffler
custom y pipe
AFCO ALuminum Radiator
Dual E-fan
Suspension:
Rotora 355mm 6 piston fronts and 4 piston rears
Tundra racing 2 in lowering sleeves in the front with bilstien shocks
Custom air ride in the rear with the help of Tundraracing again...Great guy Tom is!
Addco sway bar wit ES poly bushings and bilstien shocks as well.
Wheels:
Work Crag sk5
20x9 +15 all around with a .5in spacer in the rear wrapped on BFgoodrich KDW 265/50/20.
I believe thats it...lol
Current numbers. 296TQ and 230hp. N/A
After talkin to Dave today seems like my entire set back has been my wack azz factory y..been holdin me back...piece of crap
Latest Dyno in 4th:
http://www.xr-underground.com/vb3/showthread.php?p=830328&highlight=whitebeauty+dyno#post830328
Some more pics to look at:
http://www.toyota-4runner.org/members/whitebeauty-albums-06+runner+xsp.html
My plans for this:
Current mods:
Fully built 1Grfe
JE pistons
ARP headstuds
Ferrera Valve train
Apr fuel rails
APR 7th
APR 2.6 pulley
NST wp/alt/
Dtlt headers
Magnaflow muffler
custom y pipe
Dual E-fan
Suspension:
Wheels:
Work Crag sk5
Latest Dyno in 4th:
