- Dec 10, 2006
- 9,069
- 44
Source: www.toyotanation.com
I finally got the time to add a 750 watt inverter and plugs to my double cab. I'm not sure why the car makers don't do this. I just took the inverter apart, and extended all the wires for the plugs and switch. I connected the inverter to constant power so that you can have 110 AC power whenever you want and not have to have the key in the ignition (like you do with the stock inverter in the bed). I installed the on/off switch to control the power to the inverter. I also installed the green LED which lights up when the power is on, and a red LED tells when the inverter is being overloaded or malfunctioning. Everything works perfect and looks better than I expected.
Under that bracket is the stock inverter if you have the 110 AC bed outlet option.
Circuit breaker and 8 guage power wire running back to the inverter. The thing to the right of the circuit breaker is the siren for my CompuStar alarm.
Inverter under the driver side seat. Also notice the little heating ducts to keep the rear passengers feet warm. I didn't know those were there until I took out the seat.
I put the plug on the left hand side because the trucks' airbag controller is on the right hand side, behind a panel.
I also added a 12volt "cigarette lighter outlet" which is on constant power, so you can charge up your cell phone even when the ignition is off, unlike the stock outlets.
