Ah another great achievement was accomplished yesterday. Finally got one more piece of the puzzle completed. One huge issue with trying to race/drift a truck is the lack of proper rear suspension. Now, because the fact trucks have only one thing keeping the rear axle under the truck, the springs them selves. Now, using something flexible to hold the axle under the truck....can cause a few issues when you start throwing corning g's at the truck. For instance, check this older video of my truck autocrossing, note how much the axle shifts side to side....:thumbdown:
[ame]http://www.youtube.com/watch?v=BcZC8i4CAjs[/ame]
And now, i've finally come up with my own solution... a pan-hard bar. Some pictures of its install...:top:
We started by boxing the frame and adding a support bar to connect both sides of the frame. The Panhard bar is going to put all of sideways force on the passenger side frame rail and it can actually twist the frame and still allow it to flex the frame and "twist it"
Next step came mocking everything up.
Before we burned everything in, we checked the alignment and checked for any clearance issues. Found known, and burned it in.
....and...painted it pink...:smile:
The black paint is rubberized undercoating....and the pink bar, was much less black smudgy, until my gloves, covered in black rubberized coating and grease, and touched it...:rolleyez: oh well.
Now, if you noticed, the mount on the axle was reinforced and gusseted, for added strength...
Now, before you mention suspension binding, let me add this: I have 3-1/2" of travel from full droop to bump stop. With the panhard my axle shifts aprox. 1/16" during its travel, due to the panhard bar.
Now, A Watts link (like what OXI had on his race truck, 5 years ago) is a better device in controlling side to side axle movement, and can help prevent suspension bind up when used with leaf springs. But, not too say it has not been done before with leafsprung cars/Trucks. Ford lightnings and first Gen Mustangs have various kits available.
Notice how level the panhard bar is to axle, with full weight of the truck on it. That helps prevent axle bind by allowing as little suspension bind and shift as possible during the axles normal travel.
....now the big question...DOES IT WORK???
Uhhh...honestly, i feel like i'm driving a completely different vehicle. Its entirely the bizarre thing i cant even pin point what it feels like...
Started off with hitting some deserted roads, trying some aggressive slaloming and noticed the truck felt...strange...felt stable, steering felt responsive and the truck felt strangely planted... liked it, but nothing extraordinary.
Moved on to some on/off ramps...Started off with some aggressive, nothing limit pushing, just standard aggressive cornering. Do note, its about 10:30 pm, freeways are clearing up nicely. OK, so came into the first ramp at a typical speed i would, dab of brakes and turned in...and my life changed entirely...
It felt like i was coming in at half the speed! What. The. Hell. Have i done. My friend, who has been in my truck through every single stage of build, from stock to this...Came out of the off ramp no problems to be found. We both looked at each other and started laughing. :laugh:
The ass end of the truck felt like i was driving on rails. Completely different feeling then anything i have ever felt. The amount of grip i was getting from the ass end was extraordinary. :blurock:
Hit up a few more off ramps, and felt exactly the same results. It felt like i was driving at a much slower speed then what i really was...I love it.
Now, i also tried over driving it...getting it crossed up, seeing how it felt at/past the limit. I can steer the truck, using my right foot... dab of gas gets the ass end out, immediately. Dive in too hot, let off, and front end tucks in. Mid line corrections with the wheel do not make you question what the ass end is doing...It is scary predictable.
Now, when i got it crossed up, the ass end out and you can catch it and get back i line, with out any abrupt responses from the chassis. I could feel exactly what the truck was doing, through the seat of my pants.:top:
Sorry for the long winded update, but this made the largest improvement of any modification to the truck, other then maybe the quick steer knuckles which in all fairness only helped drifting. While this MASSIVELY improved the feel of the truck, in entirely. :blurock:
