The following is for NHRA sanctioned tracks.
Here are more details on a driveshaft loop. It must be a 360 degree enclosure minimum 1/4" thick and 2" wide. It must also be mounted within 6" of the front U-joint. Summit or Jeg's sell universal NHRA accepted loops.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CEE%2D3028&N=700+115&autoview=sku
Also, if you run aftermarket wheels (like Weld Drag-Lites) with shank style lug nuts, the stud must protrude into the hex portion of the lug nut at least the diameter of the stud. In other words, a 12mm stud must protrude at least 12mm into the hex of the lug nut. As mentioned previously, lug nuts must be open ended in order for the tech inspectors to check if you're meeting the requirements. A current Snell approved helmet is required if you're running 13.99 or quicker. Snell 95 helmets are expired. It can be full face or open face. This is a gray area but all non-OEM supercharged, non-OEM turbocharged, or nitrous equipped cars with an OEM or .024-inch steel firewall running 10.00-13.99 need an SFI Spec 3.2A/1 jacket.
Here are the rules from my track.
-All cars are required to have working seat belts
-Drivers in all cars running 13.99 or quicker (8.59) are required to have a Snell approved helmet, 80, 85, 90 of SFI 31.1 or 31.2 specs
-All drivers are required to wear long pants and a tee shirt. No tank tops are allowed
-A roll bar is required in cars running 11.49 or quicker (7.49) except for convertibles which are required to have a roll bar if running 13.99 (8.59) or quicker
-A drive shaft loop is required if the car runs 13.99 (8.59) or quicker with racing slicks or 12.99 (8.14) or quicker on street tires
-Roll cages are mandatory in cars running 9.99 (6.99) or quicker
-Drivers in cars running 9.99 (6.39) or quicker are required to wear a fire retardant jacket, pants and neck collar of SFI approved spec 3.2 A/5
-Any car running 10.99 (6.99) or quicker is required to have a SFI approved harmonic balancer. No stock balancers will be allowed
-Full all leathers are mandatory for the riders of motorcycles running 120 MPH or faster. Leather boots or shoes above the ankle, leather jacket and leather gloves are mandatory for the riders of all motorcycles
-Drivers of cars running 9.9 (6.39) or quicker are required to have a valid IHRA competition license
-Vehicles must have one functional tail light for night operations. Flashing, blinking or strobe lights will be fine
-Any car running 9.99 (6.39) or quicker which has a full roll cage is required to have a SFI approved window net
-No two steps, no throttle stops, no trans brakes, no delay boxes and no electric or pneumatic shifters in the Footbrake Class
-All cars running 9.00 (6.39) or quicker must have chassis certifications. Cars in the Trophy eliminatory will be restricted to 13.00 or slower
