***Sorry for the big pictures*** Here is where I'm at. The negative side of the battery was disconnected while I was taking pics but that definitely isn't my problem right now. I had the driver side working at one point and then removed the battery, tucked all the parts away neatly and started doing the other side. Once I got everything wired up I put the battery back in and I could no longer get the main part of the headlights to work anymore. Here is where everything is plugged in at.
I put the wire with the fuse on the positive side of the battery.
Coming off of the ballast I put the ground on the ground for the negative side of the battery
Some of the other cables. The rest seem to really only be able to plug into one spot.
I put the main set of wires on the driver side and there was a place for this plug but on the passenger side I'm not sure what to do.
