utixrunner
- Jun 17, 2007
- 1,793
that might make a diffrence, hope it works :top:
SignUp Now!Whoops, just realized that stock map is set for PSC and not the additional injector controller:rolleyez:
Looks like i'll be trying it again in the morning..
If you need the map that ships with the supercharger kits email me.
good to hear all that water/meth didnt go into your engine! I dont know a whole lot about the urd system with the 7th injector and all but when I had my 05 turboed I had to upgrade the fuel pump or else I wouldnt get enough fuel. Just a thought.
Please refresh me on the Ratios.....
Where does the stock FTC map put you at idle, normal driving and in boost?
My wideband isn't in yet?
The map I gave you is right......right?
So the stock truck used to put me around 12:1 in WOT?
I want to achieve 11:1 in through the RPMS in WOT with the FTC?
and the stock give me 10.5 to 1...so 11:1 is leaning it?
The map you gave me is correct, i just apparently have other things wrong with the truck...
I dont know what your stock AFR would be a WOT (without the S/C that is)
The stock map in the FTC should put you around 10.5 (check it with a wideband) and yes going to 11:1 would be slightly leaning it out.
did you hear anything from gadget about the 7th injector?
I have that, but that doesn't read the open and closed loop modes in your stock ecu.
any good news spyder?
