butters607
- Oct 3, 2009
- 3,826
Yea that crankshaft sensor would be easy to replace just pop the belt off and then maybe like 6 bolts
SignUp Now!Yea that crankshaft sensor would be easy to replace just pop the belt off and then maybe like 6 bolts
its just in a crappy area to work tho. shouldnt be to bad since all my skid plates are off and if i get the tire off would be easier
Why the tensionor pulley bracket just loosen the tension pop the belt of unbolt the ac compresser and unbolt the sensor
Yea jack it up good get it good and high off the ground I could have that thing out in 20 minutes or less to bad ya werent closer haha
Don't worry about the crank sensor. CHECK THE CAM TIMING FIRST.
Well, that is weird with the crank sensor. Maybe....... keep us posted.
so, a little update. decided to try and pull the APR X-1 again. didnt solve the problem but it did let the engine actually run so i could see if it would throw a code or 2. the codes it threw were
after that, for shits and giggles, i decided to swap the cam sensors. when i did that, i got this:
also, during the "idle" this is what my adv timing is
the engine smells like its running rich since i can just flat out smell fuel after it runs for a little bit.
the next thing im going to check is the actual timing again. gotta figure out what a good day to do this.
The timing looks close to where it's supposed to be change that crank sensor yet?
yep, changed it out. no change. its the first thing i did today. then did all the above
Dang man that's not good
im guessing if its stretched, ill need to have it replaced huh? no fixing it other wise?
