dramad1
- Mar 27, 2010
- 2,367
I just realized I have been cluttering up g's ucon thread with my issues that have nothing to do with the ucon. I apologize g.
I have 12 trouble codes. Fml. Lol
P0351, p0352, p0353, p0354, p0355, p0356 and all the same codes showing as pending for a total of 12.
I have tried clearing all codes. No worky, I have disconnected the battery for twenty minutes and the codes still return. I have inspected all plugs and have looked several times at the wiring and ground.
Car will turn over then just die a few seconds later. I have replaced the fuses and relays and still not the issue. I am down to the issue being the injector coils or a wiring issue not sure. Is it possible for a six coils to go bad?
Is there specific wires that get tapped when hooking up the maf cal or urd tcai that affects the injector coils. I ask because I have had both of these mods in the past and those are the only wires I messed with on the truck.
I also have a viper 5901 alarm on the truck that was though to be causing the issue but in my opinion the alarm hasn't had any issues and still seems to be doing everything like normal without any issues. I have also looked at the keys for the x being coded or sinced to the truck. I have three sets and all three start the car and then it dies.
Is it possible that I may have an air or vacuum leak that may be setting off these injector coils codes?
I am not sure at all what to do. I'm trying to figure this out with out a shops help but the issue has not gotten any closer to being resolved.
Any ideas fellas? I need my x back.
