I just finished installing urd fuel pump and truck won't start. Truck had barely any fuel in the tank, when we bled the fuel system c/opn relay was removed and cranked the truck over while jacked up it wouldn't even fire up so we figured it was bled. The install was done as directed but the c/opn relay wasn't installed in the orginial spot and still no go. I poured more fuel in the tank and tried again and still nothing. Checked fuse box and realized the relay wasn't in the right spot so I tried a third time and still the truck won't start. I hear the fuel pump turn on after I try cranking the engine over, not sure if the relay is pooched or does the fuel pump need to be primed?
