sdxrunner619
- Jan 20, 2010
- 3,836
- 7
Doesn't the pro charger one have a massive boost leak?
SignUp Now!you got it right?
Keith?:dontknow:
I by no means am trying to be rude at all. So please don't mistake it for that. I have no idea how much this current motor cost, that is being rebuilt. But since it was used and had high miles already, I have a strong feeling that played a hand in it. I don't know how pampered or abused it was either, in the prior vehicle. I know this is all upon reflection now, so it really isn't worth much, but at least now this used motor will be much more like a very low mile used motor. And being built by a very experienced individual. Thus, that with a new solid, fine combed tune, and you will be in tip top shape.
Now if we could only do something about lowering the temperature in EP.
He'd be better off getting a APR 7th since he has an X-1 IMO. I believe he already has a 7th for the MKI he has so not sure if the APR 7th would do anything now that I think about it. He may be better off with a Meth kit.
Hey Keith why don't u try to buy Slayor's Meth kit to help supress ur knock issues?
Meth is a bandaid and is no where near as reliable as a OEM fuel system, there are several things that can go wrong with meth kits and it adds more work of owning the truck into the mix.
The beauty of the 7th injector or E85 is that you have the reliability/safety of the primary fuel system and only need to put fuel in the fuel tank.
David/APR is correct, while meth/water injection does work you need to take into consideration:
1. Water is taking up space in the cylinder (space that can be used for fuel/air) costing power.
2. Methanol does not have the same energy content as gasoline.
3. Methanol is HIGHLY corrosive and very dangerous when it is on fire (when it burns it is almost invisible).
4. Adding water/meth is just another component to fail and cause an issue on his setup, it also requires him to add/mix methanol to the tank under the hood religiously (more work).
APR/David is trying to keep his setup as simple, care free, and reliable as possible at this stage of the game.
This http://www.behrents.com/c/Cooling-FanPacksSET.html or flex-a-lite? what size?:dontknow:
