Hey XrunnIT, do you have any updated video's and/or 1/4 mile times. I saw the power you had on the 40-90 after the rebuild. More updates on the powerful truck would be awesome.
Haven't been able to make it to the track, and probably won't get a chance until April (going back to graveyard shift for Feb and March).
A couple updates though since you asked.
2.6" Upper pulley + NST lower S/C Pulley is too much overdrive for the blower. There isn't any mechanical risk to the blower, its still well within its RPM limit. Problem is the blower makes too much heat at those speeds to make anymore power. I was making anywhere from 11psi to 13psi.
I had to pull my tune back a lot to keep things cool. So all the extra HP from the extra boost was lost to heat and to having to tune back. Even then, the amount of lowend torque I had was just retarded.
I took Jeffsnaustx out for a spin yesterday after the local meet. Was cruising ~40-ish in 2nd and stepped on it, and if Jeff reads this he can explain the feeling. But my KDWs didn't even try to hold the power, and the backend was all over the place. In another thread he said "his truck felt like a camry" after going for a spin. And he's supercharged.
I just removed the NST lower today, and will run this way for a while. That 2.7" upper and then APR 2.85"/URD 2.825" + NST combination seem to be right in that sweet spot (maximizing performance without being subject to overwhelming heat soak). The 2.6" upper by itself is still just a tad more then those (got to stay ahead of the game) so we'll see how that runs. It should put me about 9-11psi.
Still got a lot of HP mods in the works. Including redoing all my exhaust. A good exhaust on my setup should net me some massive gains. So still lots of custom parts coming, the mass-produced bolt-on parts just aren't good enough for me anymore. :top:
