XrunnIT
- Jul 29, 2007
- 8,044
- 1
It's hopping pretty good most of the way through first. I will try those settings thanks.
Are you hopping or spinning?
When are you hopping or spinning (when does it start)?
What setting do you have your shocks on? Shocks tuned well will reduce wheel hop a little bit.
The base line I setup was made for F/I, and it pulled enough power to keep my torquey low-end at bay enough so that it didn't spin. But depending on how sticky your tires/road is that your launching on, its very possible. The stickier your tires, the more wheel-hop you'll get.
I would say lower your launching RPM a little bit and go from there. Get some traction bars man, that will help cure wheel hop :top:
