X-roller
- Sep 6, 2008
- 5,448
- 2
hey ima newb to the x runner scence i just bought mine 2 weeks ago and im having the same issue as NTINHRI
"5th actually grinds at high speeds and high rpm if you shift normal. If I press the clutch bump like im going to shift to 6th but then push up to 5th no problem. If not 5th will grind. Also normally 90% of the time I shift 1-2-3-4-6 or 1-2-4-6"
can somebody give me some advice on what can cause this issue and what i need to do to solve it. i bought my truck from a dealership with a 100,000 mile warranty and the truck has 54xxx as of now. Does the truck need some better fluid or is it a syncro problem? please help. thank you
Since all you have is a 5th gear issue. I would recommend MT90 redline to see if that fixes your issue. It fixed mine right away and the shifts are a lot smoother. I still have a second gear grind but I think I know what that issue is. Hopefully i'll tear into the tranny next weekend.
