TitanRattler813
- Feb 28, 2007
- 7,656
- 33
I thought Rain-X was like some of those other products where the more you use it, the more you need it.
SignUp Now!I thought Rain-X was like some of those other products where the more you use it, the more you need it.
found this on the website"Ask the Van"no heater i just walk outside to it and its fogged how would the circulation help?
Often, the air in the car will be warmer than the air outside the car (this happens in winter here). Moisture will condense on the inside of the windows if the outside air is cooler than the dew point inside the car.
:top: you're welcome. Yep, most likely the weather.:rock:thanks, I think that must be it, warm and sunny in afternoon heats up inside, then it gets cloudy and temp drops in the evening causing the temp difference from inside to out
I have the same problem. I know that the makers of rain-x also have a product for fog. I'll try it today and will post the results here.
