ok so who has blown a stock tranny? im not saying 5th gear grind and everything, but actually blew a tranny from too much power?
ok think realistic,
t56- 1500-2k
t56 kit- 1600
rear end gearing- 800 up
driveshaft modded to accept 29 spline t56 -300 or so
if decide to get after market clutch and flywheel- 600 and up
for that why not rebuild the stock tranny?
1-2 shift a joke? thats why u dont need a t56, if you dont have enough power/torque to compensate then how are you going to benefit from a t56? just because closer gearing? then what? why not focus on getting more power to compensate and save some money. for the price of a t56 swap you could easily have a built 1gr:top:
ok think realistic,
t56- 1500-2k
t56 kit- 1600
Rexrunner exploded a clutch through his transmission. And my theory is that the trans is causing some of these clutch problems beside just being bad clutch discs.
Why do you think we need a ford 9" rear end? No one has blown out the rear end either. That can be addressed when we start having problems with that.
1-2 gearing is a god damn joke on these things. cut your rpms in half on the shift and you loose all momentum. Needs closer ratio through the low gears and spread it out more up top. Like the T56 has.
If your waiting for a few hundred dollar fix for the trans your gonna be waiting awhile. Anything is going to cost money. And I guess I am just willing to spend a little more to make my truck enjoyable to drive again.
I figured something would happen now that it's in the new camaro, hopefully they can address the issues and beef this thing up.
I still think I am going with the T56 swap if it develops into something.
