got another update with pics!!!!!! ok 1st up is the wire i tapped into this red and black wire is the one used for the intercooler pump on the mk1 kit since its not used with the new supercharger kits i used it for my ignition wire on the relay
2nd is a picture of the fan mounted to the oil cooler very simple you just push these right through where the fins are and on the back there is a clip that keeps them from releasing. also if you have the intercooler i have from urd you want a 90 degree push lock fitting to make it clear the space is very tight that would be the one i took off on the left and replaced so 90 on passenger side of cooler or left if your looking at the truck from the front.
3rd. this hole is located underneath the hole for the ac line drivers side or right side if your looking from the front.
4th where and how it is mounted ok looking from the front of the vehicle there is a frame rail on the right i went around that with the exhaust hanger also the hanger on the left goes around the aluminum piece located behind at the bottom of the front bumper.
here is the relay mounted on the bottom of the fan shroud upside down so water cant run into it i got it for 34.99 at autozone and it can control up to two electric fans! it also has a thermostat built in and can turn on between 160-240 degrees!
