Slywhitty
"Midget Magnet"
- Jan 26, 2008
- 3,394
- 8
Yes and yes. I'll post in a bit.
Thank you sir!!
SignUp Now!Yes and yes. I'll post in a bit.
It would be nice to know if there is a noticeable difference after this is done, nothing else changed.
I pluged off the intake port and just run the pcv system to vent on but sides. I put a catch can on that I had and just need air filter now. I am pulling a lot more vac now on the gauge. The boost is the same. No cel. I felt no difference in power. But the crank case has to feel better.
http://www.treadstoneperformance.com/product.phtml?p=68052&prodname=Vacuum+Check+Valve
3/8"
Only necessary on pre-throttle body F/I applications. The next best thing is to completely remove the pcv system from the intake. Make it a vent to atmosphere setup with a catch can. Then boost pressure can never get into the crank case, minus the minimal compression ring blow-by. Unless a ring land goes bad.
