SignUp Now!You slacker. :eviltongue:
At least update this build with your car upgrades. :eviltongue: :eviltongue:
Here's a good update on the truck
1) FINALLY got a boost gauge installed! Got this one second hand though so its not brand new!
So you can see i Tee'd in the boost line of the supercharger and so far the gauge is only reading a peasy 7psi!! WTF should be around 9 at least with the 2.7 pulley!! (Note: Elevation is only at 1200ft)
2)Got the issue of my fuel line always being empty making the engine crank over some more before the fuel lines are pressurized. In line check valve solved that issue!
Thanks man!gauges look great man! still gotta do mine one of these days but the price of a couple good gauges keeps scaring me away. if your exhaust was completely stock ya you would probably see closer to 9 psi but the more you open up your exhaust the lower the pressure....less boost...more power!
Looking good!
Be sure to put some clamps on the fittings for fuel and boost to be sure there are no leaks. No need in chancing giving yourself or the ecm a false reading and a potential popped motor.....
I don't usually see more than 7 psi and I have 2.825" pulley + NST overdrive
