SignUp Now!What you talking about? Its got ALL the low end and thats all you need. (TW logic) lol
What is it suppose help u with
But i thought he was n/a
I keep seeing this thread and want to post in it so here goes,
Can I get a rough hp estimate. I hq e never dyno'd the x but am curious what kinda power I may be putting down.
Here is a list of mods:
Nst mani spacer
Afe stage 2 si
Jba LT's
Urd mkii 3" cb
Ss street drop & xii sway kit
Just looking for a rough estimite on hp
Future mods:
Urd y pipe
Ucon ems
Bbk
Trd sc
Wal 255 fuel pump
Composite leafs
Wide band
Second muffler or resonator
Few other questions, would upgrading the fuel pump help my numbers being n/a? And if I did could I or would I be able to upgrade the injectors to say 425's? If so would I have to have a tune.
It may be a while before I'm able to upgrade to a sc so I may pick up a
Maf cal as I sold my old one. If I needed to toon for bigger injectors could I use the maf cal?
I would like to get my x as fast as possible while staying n/a before I make the jump to a sc. Is there any other mods I can do to achieve this goal?
Thanx fellas
Nst mani spacer
Afe stage 2 si
Jba LT's
Urd mkii 3" cb
Future mods:
Urd y pipe
Ucon ems
Bbk
Trd sc
Wal 255 fuel pump
Composite leafs
Wide band
Thanx fellas
I'll touch on the injectors. Fuel pump doesnt help with numbers it just ensures that the fuel is gonna get there when u upgrade on making more power. More power equals more fuel and somethings gotta supply it.
If u get bigger injectors yes u need to tune. I believe u have to set the duty cycle if im not mistaken to what your running.
If im correct the Mafcal does not tune for injectors. Never really learned to much about it. Im more into the whole full control thing..
I wouldnt get 425's.
There is a lot of tuning the URD MAF Calibrator in closed loop mode. You cannot alter the fuel mixture in closed loop mode with it, but you can do a lot of tuning there. We have other products that are used for altering fuel mixture in closed loop.
There are a lot of intake systems on the market that are not very well designed and cause a lot of significant induced MAF sensor error. For example on the 5vz the K&N Series 63 will cause the engine to run very lean and cause a significant positive fuel trim deviation. The Volant for the 1GR Tacoma makes the engine run very rich and causes a significant negative fuel trim deviation in closed loop from the ECU trying to compensate for it. The there is the new TRD for the 1GR Tacoma that make the engine run lean and a significant positive fuel trim deviation in closed loop.
We use the MAF Cal in closed loop to recalibrate the MAF sensor to the new tube and fix the induced sensor errors caused by poorly designed intake systems. Still tuning closed loop and fixing problems. So, yes there is a lot of closed loop tuning to be done with the MAF Cal.
You can also compensate for injectors that are different size from stock.
Just wanted to clear that up, the rest of the post is on target.
Nst mani spacer
Afe stage 2 si
Jba LT's
Urd mkii 3" cb
Future mods:
Urd y pipe
Ucon ems
Bbk
Trd sc
Wal 255 fuel pump
Composite leafs
Wide band
Thanx fellas
