SignUp Now!yeah but....
higher CFM and 8 psi vs lower CFM at 8psi.
Higher CFM makes more power due to air volume:top:
Justin
I wasnt trying to drop an ad for STS but did want the truth to be told about it.:biggrin:
And your correct, PSI & CFM are to different measurments. Related but different.
You can have a 66mm turbo running at 10 psi and a 76mm turbo running at the same 10 psi but the 76mm turbo will generate more power because it is moving more cfm's
Boost pressure and the CFM go hand in hand to create power. You need both figures to make a valid judgment of what the FI system will do.
Yes we do but since I just registered and I am not a paying sponsor....yet, I do not want to disrespect the other paying sponsors and forum mods.
Please contact me privatley and I will give you information.
Thanks!!!
Luis
Of course, it doesn't matter if it's in your engine manifold or in a basketball. Pressure is pressure is pressure. PSI, inHg, Bar, ATM's... all the same thing :top:Agreed but PSI is still PSI. rofl. :laugh:
But CFM is not boost its a flow characteristic in itself.
but CFM ultimately determines how much air gets in
Justin
Damn I knew I forgot one.dont forget kPa :top:
Justin
Agreed.... BOOST IS BOOST THOUGH!!!!!!!!!! :laugh:
(\_/)
(")_(") !!!!!
Welcome Paradise, you finally reach, as i said in the e-mail just post around on the forums, we need help and as much info we can get on the 1GR powerplant.Yes we do but since I just registered and I am not a paying sponsor....yet, I do not want to disrespect the other paying sponsors and forum mods.
Thanks!!!
Luis
